Сообщение от SERGEY34
 Что делать?
Для начала, посмотри направляющие и механизм весь внимательно. Не исключено, что попал мусор какой то. Хорошо было бы продуть воздухом и смазать по новой. Если в люке всё же неисправность, то будет ошибка выдаваться. Но, я нАчал бы именно с визуальной инспекции механизма.
 Есть варианты перепрошивки люка
Про это не слышал. А вот система обучения оного есть.
Вот описание:
MEMORY RESET PROCEDURE
1. Please observe the following instructions while confirming the sunroof operation.
NOTE:
Do not disconnect the electronic power while the sunroof is operating or within 5 seconds after the sunroof
stops. (to wipe-out the memory of lid position and operating friction.)
2. Initialization of system should be conducted after the following conditions.
l When the battery is out or connector is disconnected while sunroof is operating or within 5 seconds
after sunroof stops.
l When the sunroof motor is changed.
l When an emergency handle is used.
l When the sunroof does not operate normally. (Incomplete initialization conditions)
INITIALIZATION PROCEDURE
If sunroof does not close or open normally, use following procedure to return sunroof operation to normal.
1. Close sunroof if it is not in close position. It may be necessary to repeatedly push TILT UP/SLIDE CLOSE
switch to close sunroof.
2. Tilt up sunroof, and release TILT UP/SLIDE CLOSE switch once.
3. Keep pushing TILT UP/SLIDE CLOSE switch. After 10seconds, glass lid will back up a few millimeters.
then will be stopped at normal tilt up position.
(Keep pushing TILT UP/SLIDE CLOSE switch during this operation.)
4. Within first 10 seconds of releasing TILT UP/SLIDE CLOSE switch, keep pushing TILT UP/SLIDE CLOSE
switch again. After 4 seconds, glass lid will be automatically TILT DOWN®SLIDE OPEN®SLIDE
CLOSE.
5. After glass lid stops, release TILT UP/SLIDE CLOSE switch later 0.5 seconds.
6. Initializing procedure is completed. Confirm proper operation of sunroof (slide open, slide close, tilt up, tilt
down).
Вдруг поможет? Исчо, посмотри сервисный мануал. Раздел
"Roof" подраздел
"Sunroof" там есть описание неисправностей и способы их диагностики и устранения.
