Greengreys вне форума Greengreys
Неугомонный мурановод
Старый #1   31.03.2009, 09:42
По умолчанию Вибрации
Последнее время стал замечать вибрации на руле и педали газа, в чем проблема? или технологическая особенность?
krufel вне форума krufel
Истинный мурановод
Старый #2   31.03.2009, 11:32
Какая может быть техн.особ-ть, если стал замечать в последнее время. Проверяй подвеску, рулевое, тормоза на люфты и изношенность.
Старый #3   31.03.2009, 11:41
Подвеску недавно смотрели все ок, колодки менял совсем недавно. Рулевое не смотрели...
Старый #4   31.03.2009, 11:42
Хотя и рулевое смотрели - меняли тягу левую.
Старый #5   31.03.2009, 11:47
Жень, а их вообще не должно быть?
Старый #6   31.03.2009, 12:06
И еще - может быть это одна и та же проблема? http://www.club-nissan.ru/forums/showthread.php?t=68236
В американском форуме пишут нечто подобное
Старый #7   31.03.2009, 12:13
Good news/bad news.
Got to the point where the MO at idle in gear started to sound like a 1974 used Chevy Pick-up with 330,000 miles.
I did not know what to think. You could not hear much under the hood but in the cabin with doors closed it sounded like an old worn out engine. It sounded like a Benz diesel from the early 70's.
Finally when I could isolate the noise as being in the cabin, I went to Nissan where a very good tech came out, listened and then brought out a stethoscope rod thing-a-ma-jig.
He had me listen to the Fuel Damper which sits in the back near the firewall. Clank, clank, clank I heard very loudly.
I said Bingo! So that was the good news.
Bad news is that stupid tin can on a hose assembly cost 180 bucks. Sheesh! Nissan charged 180 labor..double sheesh!
OK 360 bucks and I had a Nissan coupon where you spend so many dollars and get and get so much off. So they took 35 bucks off with the service coupon that I got in the mail.
Anyway, the Mo is purring like a kitten and as quiet as the day she was born.
The service advisor said there was a bulletin but I could not find one.
If anyone finds a TSB for the Fuel Damper Assembly, please post it.
Anyone else experiencing the Mo sounding like an old junk yard truck, have the tech listen to this fuel Damper device.
Bob1
Истинный мурановод
Старый #8   31.03.2009, 13:19
Вибрация только при движении? Если да, то пройдись карщеткой по внутренней стороне дисков для начала - сними грязь. Не пройдет - сделай баланс колес. Не пройдет - снова смотри подвеску и рулевое. Вибрации конечно не должно быть, но ощущения у всех юзеров разные. Съездий на сходку ниссановодов на ВГ и прокатись на чьем-нибудь МО , сразу поймешь разницу и советов дельных кило. А америкос пишет про звук, а не про вибрацию.
Старый #9   31.03.2009, 13:41
Не то немного выложил про америкоса. Вибрация не только на ходу. Колеса менял недавно, сход развал и балансировка свежие.
Истинный мурановод
Старый #10   31.03.2009, 14:52
Если не на ходу, значит, двигатель колбасит, не зря у тебя глохла прогретая. У меня тоже на горячую глохла из-за съехавшей дроссельной заслонки, когда минус АКБ надолго сбрасывал. Защита двигла стоит - у меня была вибрация об нее картер масляный колотился? Подушки двигла и АККП смотрели? Крепления вентиляторов посмотри еще.
