18.10.2013, 20:13
помогите с кодом магнитоллы
помогите с кодом моя легла,взял на разборке,подсоединил,на мониторе на желтом фоне secure и дальше ничего,ни радио ни звука
18.10.2013, 21:17
a122va, ну что - майфун код принял?
18.10.2013, 21:24
a122va, нет надпись так и висит
18.10.2013, 21:33
”Secure” on a red background indicates that there is a problem in the link between Navi control unit and Audio,
suggesting that there is either a Navigation system fault or the Navi control unit has previously been fitted in
another vehicle.
”Secure” on a green background indicates that there is a problem in the link between NATS IMMU and Audio,
suggesting that there is an audio fault or the audio unit has previously been fitted in another vehicle.
”Secure” on a yellow background indicates that the transponder (NATS key) is not working correctly or it has
When a ”Secure” message (of any type) is displayed, it can be cleared by re-initializing the NATS system using
CONSULT-II and the associated Immobilizer PIN code (there is no need to return the audio to a Clarion service
centre). If re-initializing fails to clear a ”Secure” message then the component (identified by background
color) is faulty and should be replaced.
Ищи Consult - нужно к иммо магнитолу привязать.
