Пока ждал ответа .сам нашел:
Вот данные из сервисного мануала по Альмере 16
После оборотов 3600 первый лямбда отключается,а второй если обороты от 3500 до 4000 больше одной минуты включается.
Это касется тех у кого ручная коробка,у автомата порог 3200
Если не правильно перевел ,поправьте
DTC P0031, P0032 HO2S1 HEATER
PFP:22690
Description
EBS00K4H
SYSTEM DESCRIPTION
The ECM performs ON/OFF duty control of the heated oxygen sensor 1 heater corresponding to the engine
speed and engine coolant temperature. The duty percent varies with engine coolant temperature when engine
is started.
OPERATION
CONSULT-II Reference Value in Data Monitor Mode
EBS00K4I
Specification data are reference values.
On Board Diagnosis Logic
EBS00K4J
Sensor Input Signal to ECM ECM Function Actuator
Camshaft position sensor (PHASE)
Crankshaft position sensor (POS)
Engine speed Heated oxygen sensor 1
heater control
heater
Engine coolant temperature sensor Engine coolant temperature
Engine speed rpm Heated oxygen sensor 1 heater
Above 3,200 (A/T models)
Above 3,600 (M/T models)
OFF
Below 3,200 after warning up (A/T models).
Below 3,600 after warning up (M/T models).
ON
MONITOR ITEM CONDITION SPECIFICATION
HO2S1 HTR (B1)
Engine: After warming up
Engine speed: Below 3,200 rpm (A/T models)
Below 3,600 rpm (M/T models)
ON
Engine speed: Above 3,200 rpm (A/T models)
Above 3,600 rpm (M/T models)
OFF
DTC No. Trouble diagnosis name DTC detecting condition Possible cause
P0031
0031
heater control circuit low
The current amperage in the heated oxygen sensor
1 heater circuit is out of the normal range.
(An excessively low voltage signal is sent to ECM
through the heated oxygen sensor 1 heater.)
Harness or connectors
(The heated oxygen sensor 1 heater
circuit is open or shorted.)
Heater oxygen sensor 1 heater
P0032
0032
heater control circuit high
(An excessively high voltage signal is sent to ECM
circuit is shorted.)
