Сообщение от MIGUR
 сколько штук необходимо
Дфа))) Не забудь учесть осевой зазор коленвала, в мануале все есть, размеров полуколец штуки три-четыре, не меньше
Inspection
CRANKSHAFT END PLAY
I Using dial indicator, measure crankshaft travel amount by moving
the crankshaft forward or backward, or
I Using feeler gauge, measure crankshaft travel amount with the
lower cylinder block removed.
Standard: 0.055 - 0.140 mm (0.0022 - 0.0055 in)
Limit: 0.250 mm (0.0098 in)
I If measured value exceeds the limit, select appropriate thrust
bearings.
Unit: mm (in)
Grade symbol Thickness of thrust bearing
A 2.275 - 2.325 (0.0896 - 0.0915)
B 2.300 - 2.350 (0.0906 - 0.0925)
C 2.325 - 2.375 (0.0915 - 0.0935)
OS 020 2.475 - 2.525 (0.0974 - 0.0994)
I OS 020 has part No. of 12280 2W215 and OS 0.20 marked on
bearing surface.
CONNECTING ROD SIDE CLEARANCE
I Using feeler gauge, measure side clearance between connecting
rod and crank arm.
Standard: 0.10 - 0.22 (0.0039 - 0.0087 in)
Limit: 0.22 mm (0.0087 in)
I If measured value exceeds the limit, replace connecting rod
and repeat measurement.
If measured value still exceeds the limit, replace crankshaft.
