1.Headrest 2.Front outer slide cover 3.Front inner slide cover
4.Rear outer slide cover 5.Rear inner slide cover 6.TORX bolt
7.Snap ring 8.Lumbar support lever knob 9.Headrest holder (free)
10.Headrest holder (locked) 11.Seatback trim 12.Seatback pad
13.Seatback heater unit 14.Side air bag module 15.Seatback silencer
16.Lifter lever knob finisher 17.Lifter lever knob 18.Reclining lever knob
19.Seat cushion outer finisher 20.Seat belt buckle 21.Seat cushion inner finisher
22.Seat cushion trim 23.Seat cushion pad 24.Seat cushion heater unit
25.Reclining device outer cover 26.Reclining device inner cover 27.Seat slide outer finisher
28.Seat slide inner finisher 29.Seatback protector 30.Seat harness
■ CAUTION ■ Внимание! Сделать обязательно!!!
When removing and installing, use shop cloths to protect parts from damage.
Before removal, turn ignition switch OFF, disconnect both battery cables, and then wait for at least 3 minutes.
NOTE:
Confirming a position of connector before work.
Процедура снятия:
1.Remove the headrest.
2.Remove the rear outer and inner slide cover.
3.Remove the rear inner mounting TORX bolt.
4.Remove the rear outer mounting TORX bolt.
5.Remove the front outer and inner slide cover.
6.Remove the front outer mounting TORX bolt.
7.Remove the front inner mounting TORX bolt.
8.Set seatback in a standing position.
9.Disconnect harness connector under the seat and remove harness clamps.
10.Remove seat from the vehicle.
