Поводырь вне форума Поводырь
Старый #11   28.03.2018, 14:21
Сообщение от Андрей 1960 Посмотреть сообщение
Donnerwetter!!!
Сайн байна уу, дарга!
Calibration of Decel G Sensor
If case of doing work that applies to the list below, make sure to calibration of decel G sensor before running vehicle.
Situation Calibration of Decel G Sensor
Removing/Installing ABS actuator and electric unit (control unit) ×
Removing/Installing steering components –
Removing/Installing suspension components –
Change tyres to new ones –
Tyre rotation –
Adjusting wheel alignment –
Removing/Installing Yaw rate/side/decel G sensor ×
×: Required
–: Not required
CAUTION
To calibrate decel G sensor, make sure to use CONSULT (Adjustment cannot be done without CONSULT)
1.Stop vehicle with front wheels in straight-ahead position.
CAUTION
Keep all tyres inflated to correct pressures. Adjust the tyre pressure to the specified pressure value.
See that there is no-load in vehicle other than the driver (or equivalent weight placed in driver's position).
2.Turn ignition switch ON (do not start engine) and touch ”ABS”, ”WORK SUPPORT” and ”DECEL G SEN CALIBRATION” on CONSULT screen in this order.
3.Touch ”START”.
4.After approximately 10 seconds, touch ”END”. (After approximately 60 seconds, it ends automatically.)
5.Turn ignition switch OFF, then turn it ON again.
CAUTION
Be sure to perform above operation.
6.Run vehicle with front wheels in straight-ahead position, then stop.
7.Select ”DATA MONITOR”, ”SELECTION FROM MENU”, and ”DECEL G SEN” on CONSULT screen. Then make sure that ”DECEL G SEN” is within ±0.08G. If value is more than specification, repeat steps 1 to 5.
8.Erase memory of ABS actuator and electric unit (control unit) and ECM. Refer to Work Flow (YD engine models with electric control throttle actuator).
9.Turn ignition switch OFF.
Андрей 1960 вне форума Андрей 1960
Старый #12   28.03.2018, 15:58
Поводырь, спасибо.
но.... не теряю надежду увидеть это в pdf... ;)
Старый #13   28.03.2018, 16:07
Поводырь, спасибо.
можно и так, но это как бы давно не обновленная штука, если конечно они были обновления...
Тип файла: pdf r51_english_559e_brc_0053.pdf (31.9 Кб, 31 просмотров)
Тип файла: pdf r51_english_559e_brc_0054.pdf (23.6 Кб, 15 просмотров)
Старый #14   28.03.2018, 17:12
Сообщение от Поводырь Посмотреть сообщение
можно и так,
Ну вот ведь! Умеем, когда захотим...
Спасибо!
Непонятное разнообразие ревизий ESM несколько напрягает...
Отсутствующая у меня страничка должна быть пронумерована BRC-49
У Вас - BRC-54... Имеющаяся у меня BRC-48 - это Ваша BRC-53...
Посмотрел далее: из 107 страниц главы BRC в наличии у меня 87... Пичалька
sedoy-s вне форума sedoy-s
Старый #15   28.03.2018, 22:11
А КАК ЭТО ВСЕ ОТНОСИТСЯ К ТЕМЕ?
Старый #16   29.03.2018, 02:06
Сообщение от sedoy-s Посмотреть сообщение
Так сам-же спросил:
Поводырь, .... я полазил по инету и так и не нашел где ?
( откалибруйте по новой датчик ускорений.) и где он вообще стоит ?
На что и был дан развёрнутый ответ. Что не так?
Старый #17   31.03.2018, 19:38
А это для меня ? Понять бы теперь всё это!!!
Старый #18   01.04.2018, 04:48
А это для меня ?
Так сам-же спросил
...не?
Ну... а в чём проблема?
Gogy222 вне форума Gogy222
Откуда: Братск; Авто: ниссан патфайндер 2.5 LE 2008, уже 2,5 LE 2013
Старый #19   01.04.2018, 06:43
Есть множество переводчиков, при помощи которых можно все понять.
Калибровка датчика торможения G
Если вы выполняете работу, относящуюся к приведенному ниже списку, убедитесь, что вы проверили калибровку датчика торможения G перед запуском транспортного средства.
Калибровка положения датчика деления G
Снятие / установка привода и электропривода ABS (блок управления) ×
Снятие / установка компонентов рулевого управления -
Снятие / установка компонентов подвески -
Измените шины на новые -
Обороты шин -
Регулировка выравнивания колес -
Снятие / установка Датчик скорости вращения / боковой / торцевой датчик G ×
×: обязательно
-: Не требуется
ВНИМАНИЕ
Для калибровки датчика торможения G обязательно используйте CONSULT (настройка не может быть выполнена без CONSULT)
1.Завершите автомобиль с передними колесами в прямолинейном положении.
ВНИМАНИЕ
Держите все шины надутыми, чтобы исправить давление. Отрегулируйте давление в шинах до заданного значения давления.
Убедитесь, что в транспортном средстве нет груза, кроме водителя (или эквивалентного веса, размещенного в положении водителя).
2. Включите зажигание в положение ON (не запускайте двигатель) и коснитесь «ABS», «ПОДДЕРЖКА РАБОТЫ» и «КАЛИБРОВКА DECEL G SEN» на экране CONSULT в этом порядке.
3. Нажмите «СТАРТ».
4.После приблизительно 10 секунд нажмите «КОНЕЦ». (Примерно через 60 секунд он заканчивается автоматически.)
5. Выключите зажигание, затем снова включите его.
ВНИМАНИЕ
Обязательно выполните операцию выше.
Автомобиль 6.Run с передними колесами в прямом положении, затем остановитесь.
7.Выберите «МОНИТОР ДАННЫХ», «ВЫБОР ИЗ МЕНЮ» и «РАЗМЕР G SEN» на экране CONSULT. Затем убедитесь, что «DECEL G SEN» находится в пределах ± 0,08G. Если значение больше спецификации, повторите шаги с 1 по 5.
8. Перезарядите память привода ABS и электрического блока (блока управления) и ECM. См. Рабочий поток (модели двигателей YD с электроприводом привода дроссельной заслонки).
9. Выключите зажигание.
